Replacement of TAC VZ*9 series valves with the Schneider Electric VZ*19* series.
  • Replacement of TAC VZ*9 series valves with the Schneider Electric VZ*19* series.
‎2018-09-10 08:50 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:01 AM
Cannot order the VZ*9 valves, its no longer available.
VZ*9
VZ*19E
VZ*19*
VZ*19C
MZ20
A new line of VZ valves is now available.
The old VZ series valves have been replaced with a new. The old (VZ*9) is replaced by the VZ*19* (Either to VZ*19E (Flat face) or VZ*19C (Compression).
The MZ20 actuator range can still be used with the new valve range.
For more information and details, please see  the related data sheets. VZ*9 Valves, MZ20A Actuators and MZ20B Actuators.
  • Field Devices
  • 7446
