Replacement of Satchwell "AM" series Rotary Actuator by S-E MV15B-230 Linear Actuator due to obsolescence.
  • Replacement of Satchwell "AM" series Rotary Actuator by S-E MV15B-230 Linear Actuator due to obsolescence.
‎2018-09-06 01:43 PM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:07 AM
Satchwell "AM" series Rotary Actuator requires replacement
Satchwell “AM” series Rotary Actuator installed on Satchwell MJF, MZ, MZF, VJF, VSF, VZ or VZF series Plug and Seat Valve Body.
N.B.
Where a Satchwell “AM” series Rotary Actuator is installed on a Satchwell VV Butterfly Valve Body then NO simple Actuator replacement is available.
In addition to replacing the AMS Actuator it will also be necessary to replace the VV Butterfly Valve Body.
The replacement Actuator is S-E type MF type.
Please check the latest catalog for current equipment.
The Satchwell VV Butterfly Valve Body should be replaced by a S-E Butterfly Valve Body selected from the VF208W series of Butterfly Valve Bodies.
It should be noted however that significant pipe work modifications will also be necessary in order to accommodate any selected VF208W series Butterfly Valve Body due to the differing construction of the VF208W Butterfly Valve Body.
Obsolescence of Satchwell AM series Rotary Actuator.
Replace Satchwell AM series Rotary Actuator with MV15B-230 Linear Actuator and Linkage Kit :-
AM = MV15B-230 + L7SV (880-0126-000) Linkage Kit.
N.B.
Should the Satchwell AM series Actuator include a wired Auxiliary Switch then the following Auxiliary Switch Pack S2 (880-0469-000) - two independent 250 volt 10 amp (inductive) 3 amp (resistive) rated SPDT Auxiliary End Point Switches - may be purchased separately permitting local installation.
  • Field Devices
  • 5445
