Replacement of Satchwell MJF 3-Port Flanged Valve Body due to obsolescence.
  • Replacement of Satchwell MJF 3-Port Flanged Valve Body due to obsolescence.
‎2018-09-11 07:55 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:05 AM
Satchwell MJF 3-Port Flanged Valve Body requires replacement.
Satchwell
3-Port
Plug and Seat
Flanged
Valve Body
MJF3426    MJF 3426
MJF3427    MJF 3427
MJF3476    MJF 3476
MJF3526    MJF 3526
MJF3576    MJF 3576
MJF3626    MJF 3626
MJF3676    MJF 3676
Obsolescence of Satchwell MJF 3-Port Flanged Valve Body
Replace Satchwell MJF 3-Port Flanged Valve Body with S-E V311 3-Port Flanged Valve Body of appropriate size
N.B.
Existing Satchwell Actuator installed on MJF 3-Port Flanged Valve Body may be retained for installation on replacement   S-E 3-Port Flanged Valve Body.  In such instances a S-E L8TV Linkage Kit will additionally be required.  Alternatively an Actuator from the S-E range of Actuators may be installed on the V311 3-Port Flanged Valve Body, in which case no additional Linkage Kit will be required.
IMPORTANT NOTE
It should also be noted that the face to face dimension of the S-E V311 3-Port Flanged Valve Body differs to that of the Satchwell MJF 3-Port Flanged Valve Body
Similarly, the centre line to bottom of third port dimension of the S-E V311 3-Port Flanged Valve Body differs to that of the Satchwell MJF 3-Port Flanged Valve Body
As a result alterations to the pipework connected to the MJF 3-Port Flanged Valve Body will be required.
  • Details of the Satchwell MJF 3-Port Flanged Valve Body may be viewed here.
  • Details of the S-E V311 3-Port Flanged Valve Body may be viewed here.
  • Details of the S-E L8TV Linkage Kit may be viewed here.
  • Field Devices
  • 7618
50% helpful (1/2)
