Replacement of Satchwell DRT3451 Adjustable Room Temperature Sensor by S-E STR612.
  • Replacement of Satchwell DRT3451 Adjustable Room Temperature Sensor by S-E STR612.
‎2018-09-06 02:42 PM
on ‎2018-09-06 02:42 PM
Satchwell DRT3451 Adjustable Room Temperature Sensor installations.
Obsolescence of Satchwell DRT3451 Adjustable Room Temperature Sensor
  1. Replace Satchwell DRT3451 Adjustable Room Temperature Sensor with S-E STR612
    • The STR612 provides the same functionality as the DRT3451 differing only in its appearance, dimensions and terminal identification.
  2. Equivalent terminal identification is as follows
    • STR612 Terminal 22 (A) = DRT3451 Terminal A
    • STR612 Terminal 23 (C) = DRT3451 Terminal C
  3. Connection of STR612 to CZU Fan Coil Unit Temperature Controller
    • STR612 Terminal 22 (A) – connect to CZU Terminal 9
    • STR612 Terminal 23 (C) – connect to CZU Terminal 10
    • (CZU Setpoint should be set to 10 deg C)
  • Field Devices
  • 3260
