Replacement of Satchwell AZ2401 Rotary Actuator due to obsolescence.
  • Replacement of Satchwell AZ2401 Rotary Actuator due to obsolescence.
  • DavidChild
    DavidChild
‎2018-09-06 07:27 AM
Satchwell AZ2401 Rotary Actuator requires replacement.
Field Devices
Satchwell AZ2401 Rotary Actuator installed on Satchwell MBF Series Rotary Shoe Valve Body.
Obsolescence of Satchwell AZ2401 Rotary Actuator
The Satchwell AZ2401 actuator would normally have been installed on a Satchwell MBF Valve Body.
The Actuator comprised a 6 wire electrical connection enabling it to be operated from a Satchwell Z Monotronic or CZT Climatronic Proportional Controller as follows:
Terminal 1 – Open signal
Terminal 2 – Close signal
Terminal 3 – Common
Terminal A – 135 ohm Feedback Potentiometer – winding
Terminal B – 135 ohm Feedback Potentiometer – wiper
Terminal C – 135 ohm Feedback Potentiometer – winding
If all 6 wires are connected then the AZ2401 actuator may be replaced by following SE actuators:
  • MD20B-24 + Linkage Kit 914-1070-000 from Schneider Electric and an accessory kit
  • P140A from Belimo
If only 3 wires are connected, that is to terminals 1, 2 and 3 then the P140 accessory kit is not required.
  • Field Devices
  • 19932
