Replacement of Satchwell AR Series 7 Rotary Actuator by Schneider Electric MD Series Rotary Actuator due to obsolescence. (Actuator Wiring)
  • Replacement of Satchwell AR Series 7 Rotary Actuator by Schneider Electric MD Series Rotary Actuator due to obsolescence. (Ac...
‎2018-09-10 12:23 AM
Last Updated: Crewman ContentModerator ‎2025-10-10 02:55 AM
Satchwell AR Series 7 Rotary Actuator requires replacement
Field Devices
  • Satchwell AR Series 7 Rotary Actuators installed on Air Dampers, Satchwell MB Series or MBF Series Rotary Shoe Valve Bodies.
  • Actuator types :- ARE ARM ARX ARMS
Obsolescence of Satchwell AR Series 7 Rotary Actuators
Replace Satchwell AR Series 7 Rotary Actuators with appropriate Schneider Electric MD Series Rotary Actuators and wire as follows :-
  1. Satchwell AR Series 7 Rotary Actuators installed on Air Dampers.
    • ARE
      • ARE Series 7 Wire Number 2 = MD20A-24 Wire Number 2
      • ARE Series 7 Wire Number 3 = MD20A-24 Wire Number 3
      • ARE Series 7 Wire Number 1 = MD20A-24 Wire Number 1
      • ARE Series 7 Wire Number 5 = MD20A-24 Wire Number 5
    • ARX
      • ARX Series 7 Wire Number 3 = MD20B-24 Wire Number 3
      • ARX Series 7 Wire Number 2 = MD20B-24 Wire Number 2
      • ARX Series 7 Wire Number 1 = MD20B-24 Wire Number 1
    • ARM
      • ARM Series 7 Wire Number 3 = MD20B-230 Wire Number 3
      • ARM Series 7 Wire Number 2 = MD20B-230 Wire Number 2
      • ARM Series 7 Wire Number 1 = MD20B-230 Wire Number 1
      • ARM Series 7 Wire EARTH = MD20B-230 NO EARTH REQUIRED
    • ARMS
      • ARMS Series 76021Term 3 (Open) = MD10SR-TS Blue G
      • ARMS Series 7602 Term 2 (L1) = MD10SR-TS Not used *1
      • ARMS Series 7602 Term 1 (N) = MD10SR-TS Brown GO
      • ARMS Series 7602 Wire EARTH = MD10SR-TS NO EARTH REQUIRED
      • ARMS Series 7603 Wire Number 2 = MD10SR-T Blue G
      • ARMS Series 7603 Wire Number 1 = MD10SR-T Brown GO
      • ARMS Series 7604 Wire Number 2 = MD10SR-TS Blue G
      • ARMS Series 7604 Wire Number 1 = MD10SR-TS Brown GO
*1 Disconnect from the supply, label, and make safe at the supply and actuator.
  1. N.B.
    Should the Satchwell AR Series 7 Actuator (not applicable to ARMS) include a wired Auxiliary Switch then the following Accessory should also be wired on the Schneider Electric MD Actuator as follows:-
    • MD – S1 One independent SPDT 1 mA…3(0.5) A, 250 V AC Auxiliary Switch
    • AR COMMON Wire Number S1 = MD-S1 COMMON Wire Number S1
    • AR N/O contact Wire Number S3 = MD-S1 N/O contact Wire Number S3
    • AR N/C contact Wire Number S2 = MD-S1 N/C contact Wire Number S2
    • MD – S2 Two independent SPDT 1 mA…3(0.5) A, 250 V AC Auxiliary Switches
    • AR COMMON Wire Number S1 = MD-S2 COMMON Wire Number S1
    • AR N/O contact Wire Number S3 = MD-S2 N/O contact Wire Number S3
    • AR N/C contact Wire Number S2 = MD-S2 N/C contact Wire Number S2
    • AR COMMON Wire Number S4 = MD-S2 COMMON Wire Number S4
    • AR N/O contact Wire Number S6 = MD-S2 N/O contact Wire Number S6
    • AR N/C contact Wire Number S5 = MD-S2 N/C contact Wire Number S5
  2. Satchwell AR Series 7 Rotary Actuators installed on Satchwell MB Series Screwed Rotary Shoe Valve Bodies.
    • ARE
      • ARE Series 7 Wire Number 2 = MD10A-24 Wire Number 2
      • ARE Series 7 Wire Number 3 = MD10A-24 Wire Number 3
      • ARE Series 7 Wire Number 1 = MD10A-24 Wire Number 1
      • ARE Series 7 Wire Number 5 = MD10A-24 Wire Number 5
    • ARX
      • ARX Series 7 Wire Number 3 = MD10B-24 Wire Number 3
      • ARX Series 7 Wire Number 2 = MD10B-24 Wire Number 2
      • ARX Series 7 Wire Number 1 = MD10B-24 Wire Number 1
    • ARM
      • ARM Series 7 Wire Number 3 = MD10B-230 Wire Number 3
      • ARM Series 7 Wire Number 2 = MD10B-230 Wire Number 2
      • ARM Series 7 Wire Number 1 = MD10B-230 Wire Number 1
      • ARM Series 7 Wire EARTH = MD10B-230 NO EARTH REQUIRED
    N.B.
    Should the Satchwell AR 7 Series Actuator include a wired Auxiliary Switch then the following Accessory should also be wired on the Schneider Electric MD Actuator as follows :-
  3. Satchwell AR Series 7 Rotary Actuators installed on Satchwell MBF Series Flanged Rotary Shoe Valve Bodies
    • ARE
    • ARX
    • ARM
    N.B.
    Should the Satchwell AR Series 7 Actuator include a wired Auxiliary Switch then the following Accessory should also be wired on the Schneider Electric MD Actuator as follows :-
  4. Product Information.
    • For details of AR Series 7 ARM ARX ARE please see here
    • For details of AR Series 7602 and 7603 please see here.
    • For details of the MD10 SR Damper Actuator please see here.
    • For details of MD10A please see here
    • For details of MD10B please see here
    • For details of MD20A please see here
    • For details of MD20B please see here
    • For details of MD-S1 please see here
    • For details of MD-S2 please see here
  • Field Devices
Tags (3)
  • 5741
  • GaryMontague22
  • GaryMontague23
