Replacement of Satchwell ALM series Linear Actuator by S-E MV15B-230 Linear Actuator due to obsolescence. (Actuator Selection)
  • Replacement of Satchwell ALM series Linear Actuator by S-E MV15B-230 Linear Actuator due to obsolescence. (Actuator Selection...
‎2018-09-06 02:06 PM
on ‎2018-09-06 02:06 PM
Satchwell ALM series Linear Actuator requires replacement.
Satchwell ALM series Linear Actuator installed on Satchwell MJF, MZ, MZF, VJF, VSF, VZ or VZF Series Plug and Seat Valve Body.
Actuator type :- ALM series
Obsolescence of Satchwell ALM series Linear Actuator.
Replace Satchwell ALM series Linear Actuator with MV15B-230 Linear Actuator and Linkage Kit :-
ALM = MV15B-230 + L7SV (880-0126-000) Linkage Kit
N.B.
Should the Satchwell ALM series Actuator include a wired Auxiliary Switch then the following Accessory should also be installed on the MV15B-230 Actuator as appropriate :-
S2 – MV15B = Two independent 250 volt 10 amp / 3 amp rated SPDT Auxiliary End Point Switches.
  • Field Devices
  • 4669
