Replacement of ARE, ARX and ARM rotary actuators
  • Replacement of ARE, ARX and ARM rotary actuators
  • DavidChild
    DavidChild
‎2018-09-06 02:15 PM
Last Updated: Sisko DavidChild Sisko ‎2021-03-18 04:17 AM
Field Devices
  • Satchwell ARE1xxx
  • Satchwell ARE2xxx
  • Satchwell ARE7xxx
  • Satchwell ARX1xxx
  • Satchwell ARX2xxx
  • Satchwell ARX7xxx
  • Satchwell ARM1xxx
  • Satchwell ARM2xxx
  • Satchwell ARM7xxx
Obsolescence of Satchwell ARE, ARX and ARM actuators.
ARE actuator                                                               Replaced by
ARE1301        MD20A-24 (p/n 875 1029 000)
ARE1302        MD20A-24 (p/n 875 1029 000)
ARE2301        MD20A-24 (p/n 875 1029 000)
ARE2302        MD20A-24 (p/n 875 1029 000)
ARE2303        MD20A-24 (p/n 875 1029 000)
ARE2304        MD20A-24 (p/n 875 1029 000)
ARE2351        MD20A-24 (p/n 875 1029 000)
ARE2352        MD10A-24 (p/n 875 1019 000)
ARE2354        MD10A-24 (p/n 875 1019 000)
ARE2355        MD10A-24 (p/n 875 1019 000)
ARE7301        MD20A-24 (p/n 875 1029 000)
ARE7303        MD20A-24 (p/n 875 1029 000)
ARX actuator                                                               Replaced by
ARX1201        MD20B-24 (p/n 875 1025 000)
ARX1202        MD20B-24 (p/n 875 1025 000)
ARX2201        MD20B-24 (p/n 875 1025 000)
ARX2202        MD20B-24 (p/n 875 1025 000)
ARX2203        MD20B-24 (p/n 875 1025 000)
ARX2251        MD10B-24 (p/n 875 1015 000)
ARX2252        MD10B-24 (p/n 875 1015 000)
ARX2253        MD10B-24 (p/n 875 1015 000)
ARX7201        MD20B-24 (p/n 875 1025 000)
ARM actuator                                                             Replaced by
ARM1601        MD20B-230 (p/n 875 1021 000)
ARM1602        MD20B-230 (p/n 875 1021 000)
ARM2601        MD20B-230 (p/n 875 1021 000)
ARM2605        MD20B-230 (p/n 875 1021 000)
ARM2606        MD20B-230 (p/n 875 1021 000)
ARM2607        MD20B-230 (p/n 875 1021 000)
ARM2651        MD20B-230 (p/n 875 1021 000)
ARM2656        MD20B-230 (p/n 875 1021 000)
ARM2657        MD20B-230 (p/n 875 1021 000)
ARM7601        MD20B-230 (p/n 875 1021 000)
To fit replacement actuator to an existing MB screwed valve use linkage kit - LMD/MB (p/n 914 1071 000)
To fit replacement actuator to an existing MBF flanged valve use linkage kit - LMD/MBF (p/n 914 1070 000)
If 1 end switches are required, the reference is MD-S1 (p/n 914 1060 000)
If 2 end switches are required, the reference is MD-S2 (p/n 914 1061 000)
  • Field Devices
Tags (2)
  • 4387
  • DavidChild21
