Replacement for sensor DEGA strap-on temperature transmitter
  • Replacement for sensor DEGA strap-on temperature transmitter
  • SESA150559
    SESA150559
‎2018-09-06 12:26 PM
Sensor DEGA is obsolete and no longer available for ordering.
DEGA:
00690080
00690543
00691544
00090563
STC300:
006920041
006920061
006920021
Strap-on temperature transmitter with 4-20mA output signal
The STC300 series sensor is replacing the DEGA series. Make sure to choose the appropriate sensor range for your application.
  • Field Devices
  • 7760
