Replacement for old sensor EG2RL
  • Replacement for old sensor EG2RL
  • SESA150559
    SESA150559
‎2018-09-06 10:47 AM
EG2RL is obsolete and needs to be replaced.
EG2RL
5552220000
Replacement of old EG2RL sensor
The EG2RL was used in pairs as Average temp sensors. Each unit contains 2 SPA (1.8kOhm) sensor elements in serial, that are then connected to the other unit in parallel.
No direct replacement is available.
  • Field Devices
  • 12101
