Replacement for actuator M6B.
  • Replacement for actuator M6B.
  • SESA150559
    SESA150559
‎2018-09-06 12:21 PM
Since the actuator M6B is no longer available in our portfolio, a replacement actuator is requested.
M6B
VTRM
Replacing the obsolete M6B actuator.
There is no replacement actuator for the M6B in the Schneider Electric portfolio. However, the manufacturer ESBE (http://www.esbe.se/) should still have the M6B in their portfolio in both 0-10V and 4-20mA versions. No cross reference to their part numbers are currently available.
  • Field Devices
  • 8093
100% helpful (1/1)
