Replacement for Forta with STS safety feature
  • Replacement for Forta with STS safety feature
  • SESA150559
    SESA150559
‎2018-09-06 12:15 PM
The STS safety feature for Forta actuators is obsolete since a few years.
Forta
STS
M700
MG900
With the Forta STS battery safety feature no longer available, a replacement actuator with similar safety function is requested.
Depending on torque requirements, the Forta M700 and Forta MG900 spring return actuators are available. Just make sure the correct closing direction (stem up/stem down) is defined when ordering these actuators.
  • Field Devices
  • 8106
