Replace existing IOU Module AC1Plus caused CX controller to reset
  • Replace existing IOU Module AC1Plus caused CX controller to reset
‎2018-09-07 07:53 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:55 AM
Switched out IOU Module AC1Plus without powering down CX controller.
Continuum Cyber
CX 99xx controller
IOU Module AC1Plus
Switched IOU module with a new module without powering down the CX controller. Cannot hot swap out IOU modules
Follow 'Replacing or Adding I/O Modules' section on page 26 located in the I/O Systems Reference Manual.
  1. Power down CX controller
  2. Replace IOU module
  • 4278
