Removing invalid alarms
  • Removing invalid alarms
  • DavidChild
    DavidChild
  • PeterEdvik
    PeterEdvik
Janeway PeterEdvik Janeway
‎2020-03-31 07:28 AM
Last Updated: Picard RobertAndriolo Picard ‎2025-03-30 04:53 PM
Alarms with an invalid Source path cannot be removed from ES or AS
  • Building Operation Workstation
  • Building Operation 3.0 and higher
The invalid path prevents alarms from being deleted. In earlier releases of EBO, there was an issue whereby an error could occur in the source path of an alarm if the Automation Server was renamed. Most invalid alarms observed originate from this type of error.
Use Alarms Integrity Check in the following steps.
  • Automation Servers first, then
  • Enterprise Server, and finally, if installed,
  • Enterprise Central last.
See Alarm Cannot be Acknowledged Due to Invalid Paths for additional details.
  1. Expand System,
  2. Right-click the Alarm Control Panel,
The command runs quickly. There is no confirmation that the check has run, but a review of the alarms will show that the invalid alarms have been removed.
Tags (4)
  • Is this still posible which version
  • PeterEdvik20
  • PeterLarsen22
  • RobertAndriolo25
70% helpful (7/10)
