Remote Client options is missing from Workstation Options in I/NET 2.40 I/NET Configuration Profile.
  • Remote Client options is missing from Workstation Options in I/NET 2.40 I/NET Configuration Profile.
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 02:11 PM
Remote Client Option is missing from Workstation Options in I/NET 2.40 I/NET Configuration Profile.
I/NET
The I/O Server must be shut down in order to make this change to an I/NET Configuration Profile.
  1. Close the Configuration Profile Editor
  2. Exit I/NET
  3. Shut Down the I/O server
  4. From the Start Menu, Open I/NET Configuration Profile Editor
  5. You should now be able to set the computer to Remote Client
  • TAC INET
Tags (2)
  • 4515
  • Remote Client
