Release system memory usage after exporting projects in PCT (Project configuration tool)
  • Release system memory usage after exporting projects in PCT (Project configuration tool)
  • StephenYang
    StephenYang
Admiral StephenYang Admiral
‎2023-05-18 08:54 AM
on ‎2023-05-18 08:54 AM
System memory usage stays high after exporting projects in PCT (Project configuration tool)
Project Configuration Tool
The exporting process increases memory usage but is still withheld by the project after the process finishes.
Close the project exported.
Labels (2)
  • Project Configuration Tool
  • StephenYang23
100% helpful (1/1)
