Rehosting licenses: max rehosts exceeded
  • Rehosting licenses: max rehosts exceeded
  • SESA150559
    SESA150559
‎2018-09-06 12:40 PM
There is a limit of allowed rehosts per year. If this limit is reached and a rehost is attempted, the following error message is given:
"The rehost of the fulfillment is denied by the rehost policy because max rehosts exceeded "
Vista 5.x
If the rehost is motivated and necessary, the policy can be overridden by PSS. If required, please contact PSS Malmö.
Manually override rehost policy by using Administrative rights on the Licensing web.
  • 7329
