Rehosting licenses; can both new and old PCs run simultaneously after rehosting?
  • Rehosting licenses; can both new and old PCs run simultaneously after rehosting?
  • SESA150559
    SESA150559
‎2018-09-06 12:34 PM
After the rehost process, is it possible to use both the old and new licenses (PCs) at the same time?
TAC Vista 5
After rehosting a license, nothing prevents you from using both the original and new license file at the same time, since there is no feedback from the system that synchronizes the usage of licenses from the same Entitlement.
It is strictly against the license agreement, and should not be used at any time. If a temporary license is required, use the existing demo license files or contact PSS for other temporary solution.
  • 7506
