Registering SigmaX on a Windows 7 Laptop
  • Registering SigmaX on a Windows 7 Laptop
  • RogerHa
    RogerHa
‎2018-09-06 12:07 PM
SigmaX does not work correctly after registering the SigmaX unlock code provided by the system.
Sigma
SigmaX
Window 7
After you have run c:\SigmaX\Bin\RegSigmaX.exe and entered the code,
When trying to run SigmaX you get a "SigmaX Authentication Failed" message.
When trying to connect the Sigma Client to the server you a "No Seats Available" message
Run c:\SigmaX\Bin\RegsigmaX.exe by using the Right-Click function "Run As Administrator"
If you are trying to connect the local client the Sigma Server will require a restart before the seats become available
  • Satchwell BAS & Sigma
  • 8352
