Recovery of XBuilder project if no copy is saved and backup was not sent to target
  • Recovery of XBuilder project if no copy is saved and backup was not sent to target
  • LeeCravens
    LeeCravens
  • Anonymous user
‎2018-09-06 03:05 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-05-28 06:43 AM
If there is no saved copy of an XBuilder project and the backup was not sent to target it may still be possible to recover some of the data to be able to reconstruct the project
TAC INET, TAC Vista
Xenta 5xx / 7xx / 9xx
Lost XBuilder project and backup was not sent to target
With XBuilder 1.5.0 or later connect to the Xenta controller through the web interface and use the Utilities > Project Tree to view the project information. Use this information as a blueprint to rebuild the XBuilder project.
If an older version of XBuilder was used then can connect to the Xenta Server with FTP. The OGC graphic files as well as the CFG files which configure the linking of points and signals can be obtained through the FTP. These files can then be imported into a new XBuilder project which can be sent to the Xenta Server.
Labels (2)
  • TAC INET
Tags (2)
  • 2046
  • PeterLarsen21
