Recommended USB converter for use with I/NET
  • Recommended USB converter for use with I/NET
  • Tom_Poovey
    Tom_Poovey
‎2018-09-06 11:35 PM
Last Updated: Administrator DavidFisher Administrator ‎2020-08-20 11:02 AM
A laptop has USB ports, but does not have serial ports. Can I/NET run using USB ports?
TAC INET
  • Windows XP
  • Windows Vista
  • Windows 7
Most new computers do not provide the “Old Style” serial ports, they now have USB ports instead.
A lot of Schneider Electric have been using the KEYSPAN USB to Serial Adapter. The Part Number is KEYSPAN – USA – 19HS. Click here for a data sheet.
This product can be seen by going to https://www.tripplite.com/
Please note that there are other products that are equally as good
  • TAC INET
  • 1206
