Rdr1Connected through Rdr8Connected - Infinity System Variables
  • Rdr1Connected through Rdr8Connected - Infinity System Variables
  • Alan_Wood
    Alan_Wood
  • Dave_Shore
    Dave_Shore
‎2018-09-06 02:01 PM
Last Updated: Administrator CraigEl Administrator ‎2025-08-29 04:38 AM
What does the Infinity System Variable named Rdr1Connected through Rdr8Connected detect?
Andover Continuum
  • CX9702
  • ACX5720
  • ACX5740
Information on Infinity System Variable named Rdr1Connected through Rdr8Connected
The Infinity System Variables — Rdr1Connected, Rdr2Connected, ..., Rdr8Connected — are used to determine the connection status of card readers on specific controller models.
Functionality:
  1. These variables return a Boolean value (true or false) indicating whether a card reader is connected to each respective channel.
  2. The controller checks the connection by monitoring the voltage applied to the reader.
  3. LED1 is used as an indicator:
    • If LED1 is correctly connected, the corresponding RdrXConnected variable is set to true.
    • If not, it is set to false.
Note:
The voltage check may cause the LED to flicker at a high frequency. This flickering is typically not visible to the human eye.
Tags (2)
  • 4808
  • AlanWood25
