Quality of tubes delivered with the SPD 310/360 series sensors
  • Quality of tubes delivered with the SPD 310/360 series sensors
  • SESA150559
    SESA150559
‎2018-09-06 10:56 AM
What quality spec does the tubes included with the sensors have?
004700320 SPD310-100/300/500/1000Pa
Differential Air Pressure
Transmitters
004700340 SPD310-1000/1200/2500/5000Pa
Transmitters
004700360 SPD360-300/500/1000/2500Pa
Transmitters
The quality of the sensors are, depending on environment where installed, vital information in order to determine if the sensor is suitable or not.
The included plastic tubing consists of the tubes and connection hose.
Tubes are from ABS Resin and the hose is from PVC.
Both materials themselves are suitable for a wide range of applications also outside and of high consistency against different influences.
But they are not especially strengthened against UV radiation.
  • Field Devices
  • 11599
