Project Configuration Tool (PCT) fails to open on Schneider Electric computer, four “could not connect” error messages are shown
  • Project Configuration Tool (PCT) fails to open on Schneider Electric computer, four “could not connect” error messages are sh...
  • Gary
    Gary
  • DavidChild
    DavidChild
  • CraigEl
    CraigEl
Gary Schneider Alumni (Retired)
‎2021-03-29 02:49 AM
Last Updated: Administrator CraigEl Administrator ‎2023-07-12 06:45 PM
PCT fails to open, presenting four 'could not connect' error messages.
  • Windows 10 version 1909
  • Windows 10 version 2004
The cause maybe a firewall, scripts or group policy not allowing PCT to install correctly.
First: check the VirtualBox Host-Only Network has the correct IP address.
This can be found under: Control Panel\Network and Internet\Network Connections\VirtualBox Host-Only Network #?\Properties\Internet Protocol Version 4 (TCP/IPv4).
Raise a case with your region's IT2929 (UK = 020 7660 2747), requesting IT install the patch to correct the issue.
IT2929 have a knowledge base article on the IT2929 system to help their representatives with this issue (KB0014074).
IT2929 will advise you to take a backup of your PCT projects, uninstall PCT and Oracle VM VirtualBox.
IT2929 will then install the patch.
Re-boot the laptop.
Install PCT and Oracle VM VirtualBox (run as administrator).
Restore your PCT projects.
Re-boot the computer.
If PCT still does not work after this, update the CCC case you have or create a new case with Product Support, providing your IT2929 KSR number is you do not have a case.
Labels (2)
Tags (3)
  • DavidChild21
  • GaryMontague21
  • GaryMontague22
67% helpful (2/3)
