Project Configuration Tool - Failed to Deploy Builder for Function Block Program
  • Project Configuration Tool - Failed to Deploy Builder for Function Block Program
  • GavinHe
    GavinHe
Sisko GavinHe Sisko
‎2023-11-09 03:04 PM
on ‎2023-11-09 03:04 PM
Need to bind program objects and as detailed in Deploying a Function Block Program to a Server it is not possible to interact (eg. bind its objects to the EcoStruxure BMS objects) with a saved program outside of Builder until it is deployed.  After creating a Builder for Function Block program it saves successfully but generates an "Undefined Problem" error when trying to deploy.
  • Building Operation Workstation
  • Project Configuration Tool (PCT)
  • Building Operation Builder for Function Block
Program execution is not enabled on the specific server within PCT
Follow the steps to enable program execution:
    1. In the PCT Client select the server containing the program
    2. Expand the Properties on the right hand side
    3. Check the "Enable Program Execution" box
    4. Save the changes
    5. Stop and Start the server as per the message to restart for the changes to apply
    6. Clear the message after restart
PCT - Builder Function Block.pngFinally, back in Workstation observe when trying to deploy the program it is successfulGavinHe_6-1699442177454.png
Labels (2)
  • GavinHeward23
100% helpful (2/2)
