Programming an 8-Bit Prox/Pin Pad Reader in I/Net Seven
  • Programming an 8-Bit Prox/Pin Pad Reader in I/Net Seven
  • Tom_Poovey
    Tom_Poovey
‎2018-09-11 01:55 PM
Programming an 8-Bit HID or Indala Prox/Pin Pad reader
I/Net Site with Access Control
There is a requirement to supply an 8-Bit Prox/Pin Pad reader at a site. How do I program this reader?
Attached is a PDF File that guides you through the setup if this type of reader in an I/Net Seven system. Click here to download.
  • TAC INET
Tags (3)
  • 17039
  • iportal
  • pn
