Programme a DI point into an S-UNC-AI Card
  • Programme a DI point into an S-UNC-AI Card
‎2018-09-06 02:38 PM
S-UNC-AI Card
It is possible to programme a Digital Input object at an Analogue Input hardware location and the software will treat it as a digital input.
If you are using the latest AI Card (from production code 200705) then no additional hardware is required, but the board must be left configured for "Resistive".
Older versions of the board required the addition of a Digital Input module (579-1-359), which is now obsolete.
  • Satchwell BAS & Sigma
  • 3406
