Procedure to activate the Add-on reports module.
  • Procedure to activate the Add-on reports module.
  • Sampath_Konda
    Sampath_Konda
‎2018-09-06 10:40 AM
Continuum Add-on reports module.
Received an Activation Code from the COE Team, need to know the procedure to activate the Add-on reports module.
You will receive an Email from the COE Team with the Activation Code along with Instructions on how to activate it. For your Convenience the instructions are below.
ACTIVATION INSTRUCTIONS - CONTINUUM REPORTS INSTALLED IN C:\PROGRAM FILES
  1. Make sure Continuum is not running
  2. Make sure Continuum Reports is not running
  3. Launch a DOS Command Window
  4. CD "Program Files\Continuum_Reports"
  5. Enter in lower case: reports key writer
  6. Enter the activation code. (Note: Case sensitive)
-(OR)-
ACTIVATION INSTRUCTIONS - CONTINUUM REPORTS INSTALLED IN C:\PROGRAM FILES (X86)
  4. CD "Program Files (x86)\Continuum_Reports"
  5. Enter in lower case: reports key writer c:\progra~2\continuum_reports
6. Enter the activation code. (Note: Case sensitive)Activation Instructions - Continuum Reports installed in C:\Program Files
-or-
Activation Instructions - Continuum Reports installed in C:\Program Files (x86)
Tags (32)
  • 12470
  • access
  • activity
  • alarm
  • album
  • archiver
  • area
  • categories
  • control
  • data
  • elevator
  • event
  • extended
  • ez-getfolder
  • ez-launch
  • guard
  • importer
  • lift
  • log
  • muster
  • party
  • pdi
  • personnel
  • photo
  • purge
  • remote
  • suite
  • third
  • time
  • tour
  • tracker
  • video
