Problems when copying menta code from Xenta 280 or Xenta 300 to Xenta 401.
  • Problems when copying menta code from Xenta 280 or Xenta 300 to Xenta 401.
  • Anonymous user
‎2018-09-06 01:22 PM
Receive PARSER IO ERROR 13 when direct serial downloading a Xenta 401 controller.
Menta
Xenta
Physical IO points in a Xenta 280 or Xenta 300 menta application are assigned to M0-X1, M0-U2, etc, and when these physical IO points are copied to a Xenta 401 or Xenta 401:B menta application M0 does not exist. Because these points were copied into the menta application and not created within that application or imported as a library file, simulation mode will not check this IO terminal error.
This situation will show itself by failed downloads in the system plug-in, and PARSER IO ERROR 13 when direct serial downloading.
In Menta select Options>IO Configuration Table. Click the "bound to" column to sort by physical IO within the menta file. Look for points with the M0 reference similar to the screen shot below. Set these points to the proper physical IO terminal for the application.
  • 6147
This is a heading
