Problem renaming ES or adding SmartX server to ES
  • Problem renaming ES or adding SmartX server to ES
  • Hernan_Urueña
    Hernan_Urueña
Janeway Jonas_Brissman Janeway
‎2019-06-11 02:10 AM
Last Updated: Commander Hernan_Urueña Commander ‎2025-11-18 05:08 PM
When attempting to rename an Enterprise Server (ES) or add a SmartX (Automation) server under an ES, the following error may appear:
All subservers must be online at least once before adding (renaming)
Building Operation Enterprise Server – version 2.x and later
A mismatch exists between the contents of the MountPoints and Versions folders within the ES database. Although GUID(Globally Unique Identifier)-named pairs may look similar, their contents differ—and cannot just be copied.
  • Backup: Confirm you have a clean, recent backup of the ES database.
  • Identify unmatched files: Compare the following folders:
    1. C:\ProgramData\Schneider Electric EcoStruxure\Building Operation x.x\Enterprise Server\db\System\MountPoints Hernan_Uruea_1-1763513799416.png
    2. C:\ProgramData\Schneider Electric EcoStruxure\Building Operation x.x\Enterprise Server\db\System\Versions
    3. Delete unmatched versions: In the Versions folder, delete only those GUID-named files that do not have a corresponding file in MountPoints.Hernan_Uruea_2-1763514353653.png
  • Manual comparison required: You must compare GUIDs manually or via script—files can’t be auto-synced.
Tags (2)
  • HernanUruena25
  • JonasBrissman19
100% helpful (2/2)
