Priority Value Select object. The output of Instance 31 of Priority Value Select was always 0 in a MicroNet MN 550 controller. All other instances function correctly.
  • Priority Value Select object. The output of Instance 31 of Priority Value Select was always 0 in a MicroNet MN 550 controller...
  • Gary
    Gary
  • sesa119747
    sesa119747
‎2018-09-07 02:04 AM
MicroNet 50 controller must be upgraded to firmware version 5.
This has been corrected with MicroNet 50 controller Firmware version 5 released August 2008.
Additional information on firmware 5 can be found in TPA-LOND-08-0014.00
  • Satchwell MicroNet
  • 3309
This is a heading
