Pre-entry anti-passback implementation in Continuum using Plain English program
  • Pre-entry anti-passback implementation in Continuum using Plain English program
  • RandyDavis
    RandyDavis
  • AbeMeran
    AbeMeran
Captain AbeMeran Captain
‎2020-11-30 06:21 AM
Last Updated: Guinan RandyDavis Guinan ‎2020-11-30 06:24 AM
Implementing a pre-entry access card anti-passback using Plain English program
Andover Continuum
  • Continuum Net Controller II
  • Continuum ACX 2 Controller
  • Continuum ACX 4 Controller
The anti-passback implementation in Continuum engages when the credential holder enters the area as detected by the door switch/contact. (if no door switch is configured, then the credential holder is considered to have entered the area immediately after access has been granted by the system)
When doors are located in close proximity to each other, as is the case with a bank of turnstiles, for example, the built-in anti-passback scheme is easily defeated as a cardholder is able to unlock multiple nearby turnstiles before triggering the door contact and engaging the built-in anti-passback functionality.
The simplest solution to the issue described above is to configure the door objects WITHOUT a door switch/contact, this, however, is not always possible depending on on-site requirements.
A second solution is to take control of the doors using Plain English.
The solution presented here is for a bank of three turnstiles, (A, B, and C), it uses a PE program per turnstile. The solution can easily be adapted for a bank of less or more turnstiles.
NOTE:
The PE programming here is provided as a sample, for guideline purposes only, the programs are not intended as a complete solution, significant modifications may be required for site deployment.
Program code for door/turnstile A
'This program implements a pre-entry antipassback strategy to prevent a credentail holder
'from granting access at multiple access points (i.e turnstiles) that are physically located in close proximity to each other.
' __/-\_______/-\_______/-\___
' |       Main Lobby          |
' |       Turnstiles          |
' |_____X______X______X______ |
'       A      B      C
'OPERATION
'Upon detecting a Valid Attempt at say turnstile A, the program will deny access to the card used at turnstiles B and C
'until one of following two conditions takes place:
'1-The person attempting access goes thru turnstile A as detected by the door contact. (this activates the regular
' built-in antipassback functionality if engaged)
'2-The door strike time at turnstile A expires, and the system re-locks turnstile A
'Each turnstile requires its own program, the programs will be identical except for the  'initialization line which specifies which objects the program uses
'Program written for 3 turnstiles, can be easily modified for 2 or for more than 3
'11/30/2020 v1.0 SE PSS 101010111110  **THIS PROGRAM PROVIDED FOR SAMPLE AND GUIDELINES PURPOSES ONLY**
'Program is LOOPING/AUTOSTART
'OBJECTS USED
'DOORs
'*** All the doors are configured with Door Output Channel set to ZERO
Object thisTurnstile, theTurnstileB, theTurnstileC
'OUTPUT
'*** Output wired to door striker to lock/unlock the door
Object thisDrOutput
'NUMERICs
Object thisLastCard, theLastCard_B, theLastCard_C, thisAlarmPoint
'DATETIMEs
Object thisLastCrdTime, theLastCrdTime_B, theLastCrdTime_C
Line SETUP
'ENTER THE PATH TO THE 3 DOORS HERE
  thisTurnstile = Turnstile_A
  theTurnstileB = Turnstile_B
  theTurnstileC = Turnstile_C
'ENTER THE PATH TO THE  INFINITYOUTPUT HERE
  thisDrOutput = Trnstl_A_Striker
'ENTER THE PATH TO THE  INFINITYNUMERICs HERE
  thisLastCard = Trnstle_A_CrdNum
  theLastCard_B = Trnstle_B_CrdNum
  theLastCard_C = Trnstle_C_CrdNum
  thisAlarmPoint = TurnstileA_ALM
'ENTER THE PATH TO THE  INFINITYDATETIMEs HERE
  thisLastCrdTime = Trnstle_A_EvntTm
  theLastCrdTime_B = Trnstle_B_EvntTm
  theLastCrdTime_C = Trnstle_C_EvntTm
  Goto MONITORING
Line MONITORING
  thisDrOutput Value = 0 'LOCK THE DOOR
  If thisTurnstile ValidAttempt then
'ACCESS HAS BEEN GRANTED AT THIS DOOR...
    thisLastCard = thisTurnstile EntryLastCard 'RECORD THE CARD # USED...
    thisLastCrdTime = (Date + 0) 'AND THE TIME OF THE TRANSACTION
    Goto VALID_ATTEMPT
  Endif
Line VALID_ATTEMPT
'IF SAME CARD USED AT ANY OF THE OTHER 2 DOORS WHILE THE CURRENT TRANSATION IS IN PROGRESS DENY ACCESS
  If (thisLastCard Value = theLastCard_B Value) and (Date - theLastCrdTime_B Value) < theTurnstileB DoorStrikeTime then Goto PASSBACK
  If (thisLastCard Value = theLastCard_C Value) and (Date - theLastCrdTime_C Value) < theTurnstileC DoorStrikeTime then Goto PASSBACK
  thisDrOutput = thisTurnstile DoorStrikeTime 'UNLOCK THE DOOR
  If thisTurnstile DoorSwitch = Opened then Goto PROCESSENTRY 'PERSON HAS OPENED THE DOOR
  If TS > thisTurnstile DoorStrikeTime then Goto MONITORING 'VALID ACCESS NO ENTRY
Line PROCESSENTRY
'VALID ACCESS WITH ENTRY
  If TS > 0 then thisDrOutput = Off 'RELOCK THE DOOR
  Goto MONITORING 'GO WAIT FOR NEXT ACCESS ATTEMPT
Line PASSBACK
'ANTI PASSBACK VIOLATION
  TurnstileA_ALM = TurnstileA_ALM + 1 'SEND ALARM
  Goto MONITORING
Line E
  If TS > 10 then Goto MONITORING
Program code for door/turnstile B
' |      Main Lobby           |
' |      Turnstiles           |
' | ______X______X______X____ |
'         A      B      C
'OPERATION
'until one of the following two conditions takes place:
'Each turnstile requires its own program, the programs will be identical except for the  initialization line which specifies
'which objects the program uses
'OBJECTS USED
'DOORs
Object thisTurnstile, theTurnstileA, theTurnstileC
'OUTPUT
Object thisDrOutput
'NUMERICs
Object thisLastCard, theLastCard_A, theLastCard_C, thisAlarmPoint
'DATETIMEs
Object thisLastCrdTime, theLastCrdTime_A, theLastCrdTime_C
Line SETUP
  thisTurnstile = Turnstile_B
  theTurnstileA = Turnstile_A
  thisDrOutput = Trnstl_B_Striker
  thisLastCard = Trnstle_B_CrdNum
  theLastCard_A = Trnstle_A_CrdNum
  thisAlarmPoint = TurnstileB_ALM
  thisLastCrdTime = Trnstle_B_EvntTm
  theLastCrdTime_A = Trnstle_A_EvntTm
  Goto MONITORING
Line MONITORING
    Goto VALID_ATTEMPT
  Endif
Line VALID_ATTEMPT
  If (thisLastCard Value = theLastCard_A Value) and (Date - theLastCrdTime_A Value) < theTurnstileA DoorStrikeTime then Goto PASSBACK
Line PROCESSENTRY
Line PASSBACK
  Goto MONITORING
Line E
Program code for door/turnstile C
' |      Main Lobby           |
' |      Turnstiles           |
'         A      B      C
'OPERATION
'OBJECTS USED
'DOORs
Object thisTurnstile, theTurnstileA, theTurnstileB
'OUTPUT
Object thisDrOutput
'NUMERICs
Object thisLastCard, theLastCard_A, theLastCard_B, thisAlarmPoint
'DATETIMEs
Object thisLastCrdTime, theLastCrdTime_A, theLastCrdTime_B
Line SETUP
  thisTurnstile = Turnstile_C
  thisDrOutput = Trnstl_C_Striker
  thisLastCard = Trnstle_C_CrdNum
  thisAlarmPoint = TurnstileC_ALM
  thisLastCrdTime = Trnstle_C_EvntTm
  Goto MONITORING
Line MONITORING
    Goto VALID_ATTEMPT
  Endif
Line VALID_ATTEMPT
Line PROCESSENTRY
Line PASSBACK
  Goto MONITORING
Line E
Tags (7)
  • AbeMeran20
  • anti
  • anti passback
  • passback
  • tailgating
  • turnstile
  • turnstiles
