Powering OP7 with 24VDC
  • Powering OP7 with 24VDC
  • SESA150559
    SESA150559
‎2018-09-06 01:22 PM
Is it possible to use 24VDC as power supply to the OP7?
OP7 power supply adapter included in package.
The documentation only recommends using 24VAC as power supply.
Usage of 24VDC is not tested, and therefore not recommended or supported.
Labels (2)
  • TAC INET
  • 6016
