Power consumption Forta M400
  • Power consumption Forta M400
  • SESA150559
    SESA150559
‎2018-09-06 12:48 PM
The data sheet states 2 different power consumptions:
Power consumption: average 6 VA
Transformer sizing: 30 VA
Which one should be used for calculating power supply?
Forta
There are different figures specified in the documentation for the Forta series actuator.
Average consumption is 6VA, but the peak consumption is 30VA, and this is just before the valve reaches the fully closed position.
  • Field Devices
  • 7093
100% helpful (1/1)
