Plug-in 'TACZBuilderPlugIn.Application' launch failure. Unspecified error
  • Plug-in 'TACZBuilderPlugIn.Application' launch failure. Unspecified error
‎2018-09-07 03:20 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-11-19 07:22 AM
Unspecified error
TAC Vista
LonMaker 3.X
TAC ZBuilder Plug-in
An unspecified error in the launching of the TAC ZBuilder Plug-in is either caused by a faulty installation or registration of the plug-in.
  1. Check under Start > Settings > Control Panel > Add or Remove Programs. Look for TAC ToolPack 5.X.X.
  2. Make sure the version number 5.X.X matches the current Vista installation.
    1. If it does not, uninstall the current version of the ToolPack and install the correct version.
    2. If it is the correct version, proceed.
  3. Check the plug-in registration. In LonMaker go to LonMaker > Network Properties > Plug-in Registration. Look for TAC Vista System Plug-In (Version 5.X.X)
  4. Make sure the version number 5.X.X matches the current Vista installation.
    • If it does not, unregister the current version of the Plug-in and register the correct version.
  5. If everything appears to be installed and registered correctly, but the error persists, uninstall and reinstall the correct ToolPack. Reboot the PC, reregister the plug-in, and try to launch it again.
  • 3996
This is a heading
