Plain English program editor fails to open, or crashes when editing/creating PE program with the error Plain English has encountered a problem and needs to close.
  • Plain English program editor fails to open, or crashes when editing/creating PE program with the error Plain English has enco...
  • ScottLeedberg
    ScottLeedberg
‎2018-09-06 02:12 PM
When trying to edit or create a new Plain English program the editor fails to open.
CyberStation
Plain English
Editor
Corrupted PlainEnglish.ini file
  1. Open Windows Explorer
  2. Go to the Windows directory
  3. Find the PlainEnglish.ini file and delete it.
When the Plain English editor is opened after this file is deleted it will recreate a new PlainEnglish.ini file with all the default settings.
  • 4473
34% helpful (1/3)
