Pinpoint combo box control snaps closed before an entry can be selected.
  • Pinpoint combo box control snaps closed before an entry can be selected.
  • AbeMeran
    AbeMeran
‎2018-09-06 01:50 PM
In a Graphic panel configured with a background image and several controls including a combo box control when the list is exposed (pulled down) it snaps back closed before a selection can be made.
CyberStation
Interaction between combo box control and other graphic object components such as back ground image can cause the combo box control to behave inappropriately.
For example, an overlap of the combo box control with other controls and/or images in the canvas may cause the issue.
Switch graphic to design mode and re-arrange controls and images until combo box works as expected.
  • 5144
