Pin Code or general code not working from access control keypad
  • Pin Code or general code not working from access control keypad
  • Dave_Shore
    Dave_Shore
  • PaulFr
    PaulFr
‎2018-09-06 12:36 PM
Continuum access control
Keywords: Pin Code, general code, #, 8 bit burst
Pin Code or general code not working from access control keypad.
The 4 numbers in the PIN code or General Code need to be followed by the # key
When personnel are created with no PIN number they are allocated "0" but this does not work at a PIN code. The PIN number must be changed from non "0" before it will work.
The PIN number does not need to be 4 digits long (ACX57 only fully tested)
The keypad/ reader used must provide an 8 bit burst wiegand output.
  • 7455
