Personnel templates and area links
  • Personnel templates and area links
  • AbeMeran
    AbeMeran
‎2018-09-06 03:59 PM
Questions on the relationship between the area links in a personnel template and the links in derived personnel objects.
CyberStation
Documentation
Q.
 Personnel already has a Template assigned...What happens to
the Area list when a different Template is assigned? Specifically, to
the Areas already listed, will only the new Templates Areas be left or
Is it a union or something else?
 A.
When the template is re-assigned the personnel objects will drop all areas that come from the template and pick up the areas from the new template. Areas that were assigned separately from the template (loose areas) will remain.
Also, when changing the template the system will prompt you with several options to choose from for how to handle the attributes that are linked to the template.
Q.
2 Personnel has some Areas already assigned...What happens when
that Personnel is assigned to a Template?
A.
Those areas that are not associated with a template (loose areas) will remain, the areas from the template are added to the person’s area list.
Q.
3 Personnel has a Template already assigned...What happens when
Areas are added individually?
A.
Those areas added individually (loose areas) are simply added to the person’s area list, template manipulation has no effect on loose areas.
  • 7284
