Personnel Profiles are adding areas that are not included in the profile.
  • Personnel Profiles are adding areas that are not included in the profile.
  • sesa139513
    sesa139513
  • PaulFr
    PaulFr
‎2018-09-06 10:29 AM
Users are adding areas to a person which should be blocked by a security level.
Continuum V1.93, V1.94
Object level security is allowing the personnel profile to attach areas that should be blocked.
Users with limited access to the sites areas are having additional areas added when applying a profile.
No problems are encountered if no object level security is applied to the areas.
This issue is resolved in V1.94 SP1 release of Cyberstation.
  • 13017
