Pelco Control Point Software cannot run on the same PC as I/NET Seven Software
  • Pelco Control Point Software cannot run on the same PC as I/NET Seven Software
  • Tom_Poovey
    Tom_Poovey
‎2018-09-10 11:02 PM
Can Pelco's Control Point Software run on the same PC as I/NET Seven Software?
Pelco, TAC INET
  • All Windows OS
  • I/NET Seven Software
The two software packages are not compatible with each other.
Pelco's client software cannot be installed on the same PC that is running TAC I/NET Seven.
See TCON 301 - Chapter 6.
Labels (2)
  • CCTV
  • TAC INET
  • 8018
