PSI / XPSI Revision 4.0 will not tunnel, nor will it connect via modem.
  • PSI / XPSI Revision 4.0 will not tunnel, nor will it connect via modem.
‎2018-09-07 02:28 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:54 AM
TAC IA Series
Not supported in this release.
Upgrade to PSI / XPSI Revision 4.1, which the file PSIv4.10.zip is available for download on The Exchange Download Center.
Click here to see the Release Notes included in the zip file.
  • TAC IA Series
  • 4924
