PIN locations for control for MPT24DT
  • PIN locations for control for MPT24DT
‎2018-09-11 10:06 AM
What are the PIN locations for right and left control?
MPT24DT Pan/Tilt functions, PT270-24P, PT280-24P, PT570-24P, PT680-24P
Loss of manual for PIN layout
On either a 14-PIN or a 9-PIN the following applies:
  • PIN 1 is P/T common
  • PIN 3 is Left control
  • PIN 5 is Down control
  • PIN 6 is Up control
  • PIN 7 is Right control
  • PIN 8 is Safety Ground
  NOTE: MPT24DT can also be used to control 120 VAC pan/tilt  and scanners when used with RB115 relay box
Labels (2)
  • CCTV
  • Field Devices
  • 16555
