PE commands on b3 and i2 Controllers
  • PE commands on b3 and i2 Controllers
‎2018-09-11 12:04 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:53 AM
Do all b3 and i2 Controllers support  all PE commands
b3 i2 Controllers String Trig
Some PE commands can not be used on some b3 or i2 controllers
The following Plain English system functions are not supported in the i2885, i2885-V, and i2887(L) controllers: (b3885,b3885-V, and b3887(L) controllers)
ACOS, ARCCOSINE, ARCSINE, ARCTANGENT, ARCTANGENT2, ASC, ASIN, ATAN, ATAN2, CEILING, CHR, CLOSELIST, COS, COSINE, EXP,
EXPONENTIAL, FACT, FACTORIAL, FIRST, FLOOR, GETOBJECT, LAST, LEFT, LEN, LENGTH, LN, LOG, MID, NUM_TO_STR, OPENLIST
RANDOM, RIGHT, RND, ROUND, SD, SEARCH, SIN, SINE, STANDARD_DEVIATION, STR_TO_DATE, STR_TO_NUM, STR_TO_TIME, STRINGFILL
TAB, TAN, TANGENT, VAL
See
- b3 technical data
- i2 technical data
- PE Programming guide
Labels (2)
  • 12215
