PCT (Project configuration tool) ports requirement
  • PCT (Project configuration tool) ports requirement
  • StephenYang
    StephenYang
Admiral StephenYang Admiral
‎2023-05-10 05:19 PM
on ‎2023-05-10 05:19 PM
The port range used by the Project Configuration Tool is unclear
The ports used by PCT are located in different documents
• TCP on port 4444 (fixed)
• HTTP on port 80 (default)
• HTTPS on port 443 (default)
• Server port 9091 (default)
• Server port 9090 (default)
• Engineering port 32768-61000
Labels (2)
  • Project Configuration Tool
  • StephenYang23
0% helpful (0/1)
