PCT Installation Issue Error:1722, Error:1603, "The setup has detected no version of SBO Project Configuration Tool is installed."
  • PCT Installation Issue Error:1722, Error:1603, "The setup has detected no version of SBO Project Configuration Tool is instal...
‎2018-09-10 07:24 AM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:37 AM
During certain situations, it may be required to remove and re-install PCT to address software conflicts with other software applications. While trying to remove/install PCT you may receive an error preventing you from completing the installation.
  • The setup had detected that no version of SBO Project Configuration Tool is installed.  The specific command-line options require that the application be installed to continue. The setup will now terminate.
  • Error: -1603 Fatal error during installation. Consult Windows Installer help(Msi.chm)or MSDN for more information.
  • Error 1722. There is a problem with this Windows Installer...
Client versions (64 Bit Only): Editions: Pro, Home, Enterprise
  • Windows 10
  • Windows 8.1
  • Windows 8
  • Windows 7
      Server versions (64 Bit Only): Editions: Standard, Enterprise
  • Server 2008 R2
  • Server 2012
  • Server 2012 R2
 PCT versions (64 Bit OS Only):
  • SBO Project Configuration Tool v 1.0.0.487 - SmartStruxure Solution - Software
  • SBO Project Configuration Tool v 1.0.0.510 - SmartStruxure Solution - Software
  • SBO Project Configuration Tool v 1.1.0.47 - SmartStruxure Solution - Software
  • SBO Project Configuration Tool v 1.1.1.49 - SmartStruxure Solution - Software
  • SBO Project Configuration Tool v 1.1.2.57 - SmartStruxure Solution - Software
Warning
In order to get past a possible installation loop, you will need to locate and delete the following Windows registry key: [HKEY_CLASSES_ROOT\Installer\Products\B2A4F0AEC8BB0E2438706F07E2E2560B]
Note: Always make a backup of your registry before making any modifications.
  1. Run regedit.exe
  2. Locate/Search:
    Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\B2A4F0AEC8BB0E2438706F07E2E2560B
  3. Delete Registry Key entry: B2A4F0AEC8BB0E2438706F07E2E2560B
Labels (2)
  • Project Configuration Tool
Tags (4)
  • 19756
  • issues
  • RobertAndriolo20
  • StephenYang20
34% helpful (1/3)
