Override/force an I/O point on an I/O-Module connected to a Xenta 7xx
  • Override/force an I/O point on an I/O-Module connected to a Xenta 7xx
  • sesa150555
    sesa150555
‎2018-09-06 02:39 PM
Can't  Override/force an I/O point on an I/O-Module connected to a Xenta 7xx
Vista
Xenta 7xx
Xenta 7xx way of override value has been changed from the way Xenta 4xx did
There are no way of forcing the RI/BI or RO/BO signals like you can do with the AI/AO DI/DO in Xenta 300/400/280. In the 700 you can only force the real physical point. You find the points under the Xenta Server object $IO.
  • 3357
