Operating Systems and SQL Supported in I/NET Seven 2.40, 2.40A, and 2.41
  • Operating Systems and SQL Supported in I/NET Seven 2.40, 2.40A, and 2.41
  • Tom_Poovey
    Tom_Poovey
‎2018-09-11 11:29 AM
  • Windows Server 2003 w/ SP1
  • Windows XP Professional w/ SP3
  • Windows Vista Enterprise w/ SP1
  • Windows 7 Professional 32-bit
  • SQL Server 2000 Desktop Engine(MSDE 2000) SP4
  • SQL Server 2000 Standard
  • SQL Server 2000 Enterprise
  • SQL Server 2005 Express SP3
  • SQL Server 2005 Standard SP3
  • SQL Server 2005 Enterprise SP3
  • SQL Server 2008 Express (32-bit)
  • SQL Server 2008 Standard (32-bit)
Issues may arrive if the I/NET software and SQL Server versions do not follow the below guidelines.
 Click here to download this document in PDF format.
    Operating Systems
    Windows Server 2003 w/ SP1  Windows XP Professional w/ SP3  Windows Vista Enterprise w/ SP1  Windows 7 Professional 32-bit
SQL Server  SQL Server 2000 Desktop Engine (MSDE2000) SP4   Yes   Yes
 SQL Server 2000 Standard   Yes
 SQL Server 2000 Enterprise   Yes
 SQL Server 2005 Express SP3   Yes   Yes   Yes   Yes
 SQL Server 2005 Standard SP3   Yes   Yes   Yes   Yes
 SQL Server 2005 Enterprise SP3   Yes
 SQL Server 2008 Express (32-bit)         Yes
 SQL Server 2008 Standard (32-bit)         Yes
General Notes:
  1. Do not mix versions of SQL server among equalized or client/server workstations in your TAC I/NET Seven system. Ensure that the edition of SQL server installed on each workstation used in a client/server or equalized setting are based on the same version of Microsoft SQL, either 2000, 2005, or 2008.
  2. It is strongly recommended that you defragment the PC's hard drives on a regular basis. Severely fragmented hard drives can cause poor system performance and in some cases can introduce data errors.
  3. The use of Microsoft SQL Server 2005 Standard or Enterprise edition, or any edition of Microsoft SQL Server 2008 will require that the PC have at least 2 GB of RAM.
  4. Microsoft SQL Server 2005/2008 Express Edition cannot be used on a TAC I/NET Seven filemaster.
  • TAC INET
Tags (2)
  • 5354
  • inet
