Operating System + SQL Server only allowed to be English versions
  • Operating System + SQL Server only allowed to be English versions
  • sesa139513
    sesa139513
‎2018-09-11 07:43 AM
Does the Operating System + the SQL Server needed to install the reporting package for the SmartStruxure platform only allowed to be English versions
StruxureWare Building Operation site with Reports Server
Help.SBO states:
Microsoft provides a number of versions of SQL Server. In order to install and run WebReports with Building Operation, you need to download and install SQL Server 2012 Standard, 64-bit (or Express with Advanced Edition, 64-bit). Do not install any other version of SQL Server. You can download the executable file for 64-bit operating systems:
SQLEXPRADV_x64_ENU.exe.
Does the Operating System + the SQL Server needed to install the reporting package for the SmartStruxure platform only allowed to be English versions or we could go for an Spanish/German/etc. version for both of them?
WebReports is not supported on non-English platforms.
Tags (10)
  • 16585
  • chinese
  • french
  • italian
  • japanese
  • korean
  • language
  • languages
  • portuguese
  • russian
100% helpful (1/1)
