Opening an I/NET Point through a Graphic Page results in "You do not have the Proper Password to do this"
  • Opening an I/NET Point through a Graphic Page results in "You do not have the Proper Password to do this"
  • Tom_Poovey
    Tom_Poovey
‎2018-09-06 12:54 PM
There is a Graphic Page issue in I/NET Seven rev 2.15 and below. Anytime you try to connect to a point thru a graphic page it gives you an error of "You do not have the Proper Password to do this."
  • Windows XP Pro SP3
  •  I/NET Seven rev 2.15 and below
Upgrade the site to I/NET Seven rev 2.31 or above (up to I/NET Seven rev 2.4X). The Graphic Page issue was fixed in these versions.
  • TAC INET
Tags (3)
  • 6917
  • inet
  • pages
